Help with public ip's on a LAN!!
I have a LAN setup between my 2 pc's 1 pc has a private IP and the other with the direct connection has a public ip from my isp, well what i want to do is give my other pc on my LAN a public ip address aswell, because then it will make connecting to certain things that need certain ports hassle free, like online gaming!!, Im using ICS in windowsXP if i got more ip's from my isp how would i configure this without buy a router :?
Thank You...
1 REPLY
You can't.
ICS does not support this at all.
You would either need a dedicated machine, capable of routing (certain flaviours of 2K, or linux) or a router to do this.
