Help with Linksys BEFDSR41W Router cofiguration
I have a Linksys BEFDSR41W router and having great problems in configuration.
The protocol that is used is RFC 2364 PP0A and this requires the username and login to connect. However if I configure the router for this setting it does not work.
However plusnet have allocated fixed ip address, can this be changed to server assigned ?. There are 5 modes of encapsulation.
1. RFC BRIDGED
2. RFC 1483 ROUTED
3. RFC 2364 PPPOA
4. RFC 2516 PPOE
5. BRIDGED MODE ONLY.
Which one do I use I need to enter the PPOA protocol but at the same time enter my fixed ip adrees subnet mask etc.
I have used a different router and have had no problems in its configuration so it is not my connection its knowing how to get the configuration of PPOA and entering my user name and password to log in.
Anyone with a LINKSYS router up and running with plusnet I would be obliged with any help or advice you could give. Sad
Moderators note (John) Title changed from ALL capitals to lowercase. PLease don't post in all caps as it is SHOUTING and harder to read.
hi mate
RFC 2364 PPPOA is the one that works
and in username:yourname@plusdsl.net
password:**************(you should know)
subnet mask 255.255.255.0 dont change this otherwise wont work
you do get static ip with plusnet but you dont need to do anything special as you always assigned the same ip everytime.
Username may not be @plusdsl.net, as @plus.net is also used. Unsure you use the right suffix.
According to router type, sometimes the IP address must be entered to get a connection.
csogilvie
I think @plus.net is only older accounts now, new users get plusdsl.net
Linksys BEFDSR41W is the kind of router you dont enter ip address
@plusdsl instead of @plus
go to linksys website and new firmware is there
True, but reading, it said
So I assumed an existing or older user was possible.
