Help with Fujitsu FDX310 modem please
taidi
Had to reinstall Win98 and can't remember how my Fujitsu FDX310 modem was configured, it was working OK before the hiatus Wink
It seems to connect fine but my browser just won't go anywhere.
Lots of settings in the modem control panel I honestly don't understand, - I'd be grateful if someone could advise which of the following settings I should be using.
Encapsulation
RFC2634PPPoATM LLC
RFC2634PPPoATM VC
RFC2516PPPoE
Modulation
T1.413
Multimode
G Lite
G DMT
What should my TCP/IP settings be ?
TIA
Post Extras: Print Post Remind Me!
Hi.
Encapsulation should be
RFC2634PPPoATM VC
Modulation should be
G DMT
Not quite sure which tcp/ip settings you mean
Cheers
Jon
taidi
Thanks, - they are the settings I'm using. Can't figure why my browser won't load any web pages - according to the FAQ it would be a problem with the firewall but I haven't reinstalled one yet.
I'll try raising a ticket and see if the techies can offer any help.
You got the dns entries set right?
Cheers
Jon
