Help needed with voyager 105
I need a copy of an original cd for a BT Voyager 105 model.
I could only download the driver from BT, but it does not come with all the features, namely The Diagnostic Tool. All help will be greatly appreciated.
Please mail me for address on proden@gmail.com
prichardson
You can download the driver from our website, which includes the drivers and the Dr 105 utility.
I am unsure which diagnostics tool you refer to, however you can access most diagnostics information from the drivers in our support section.
Kind Regards,
GREAT ! thanks
How do i find out my Downstream Attenuation and Downstream Noise Margin
And thanks again for the speedy reply
Thank you very much for your help!
In my line stats there are two figures :
Attenuation (dB): 46 / 26.5
SNR Margin (dB): 15.5 / 11.5
Which figures matter when I want to find out how fast my connection can be when, eventualy moved to MAX as per
http://www.dslzoneuk.net/maxspeed.php
I am on Premier Option 1 ,but still on 1meg
Downstream figures are the relevant ones.
Attn 46, SNR 15.5
