Help Needed - Confused
I just done a speed test using the bt speed test, where you have to log in with different user name and pass. I did the test and it said that i downloaded the file @ 950 kilo bits per second (this was showing as aorund 120k B\s on my download meter). so i changed my login details back to my plus net details. so i thought that everything was normal, i downloaded a file at no more of 70kB\s.
what is going on
thanks in advance
ID
what was the source you were downloading from? some servers/sites get busy etc.
LiamM
I would say it is possible that you are still throttled to 512k, but you couldn't get 70k/sec on 512k, the max would be just over 60k/s.
What product do you have? Broadband Premier ?
