Having problems with Alcatel Speed Touch USB & DSL
Hi all,
Cant be bothered to wait for my modem to arrive as it seems to be taking ages!!!
So a mate lent me his Alcatel Speed Touch USB modem to connect with. Thing is that I always get an error 650, I can never get on, it has been activated ages ago I know that!!!
How can you tell if your modem is running PPoe or PPoA?
Also how do I change things like:
Connection Protocol/ type
* PPPoA, also referred to as RFC 2364
PVC settings - Connection settings required for ADSL in the UK (PPPoA)
* VPI: 0
* VCI: 38
Encapsulation Mode
* VC MUX (Also referred to as VC Multiplexed or null)
* Home gateway name: @plusdsl.net
All this means nothing to me, when I try to set up the connection the only choices I get are the standard one like:
General, Server Types, Scripting & Multi Link and it references none of those in those fields.
Any ideas for help?
Cheers guys , I appreciate it.
Mark
1 REPLY
Have you installed the software for the modem?
Software and manuals are available from http://www.dslsupport.co.uk/st330.asp and http://www.dslsource.co.uk/product_details.asp?idProduct=38
