Has anyones tests showed above 6000kbs
I am 800m from the exchange as measured buy a friend who knows the BT test number. this test was don some years ago but i don't think either my douse or the exchange has move since then .
My router/modem stats
ADSL Link Downstream Upstream
Connection Speed 8128 kbps 448 kbps
Line Attenuation 13 db 4.5 db
Noise Margin 19 db 26 db
PlusNet eduncan@plusdsl.net
Date Speed Achieved (kbps)
28-05-2006 07:38:03 3764.1
28-05-2006 07:37:48 4927
28-05-2006 07:37:26 4320.7
Bt speed test speedtest@speedtest_domain
5418 kilo bits per second (Kbps), your service bandwidth will have been quoted to you in kilo bits per second.
I am starting to believe that it’s relay up to 6mbs not 8mbs
I have similar line stats to yourself and live around 400m from my exchange.
At quieter times of the day and night, my speeds average around 6900kbps with the best being 7800kbps (that was at 2am though).
From what stats you've stated I don't see why you couldn't get near that.
I can only think that your data rate is not set at 8000 or try tweaking your MTU and RWiN, the latter in particular gave me around another 1000kbps.
Tryed that used a program to analys my setting. changed them, nothing.
Cry
ID
DSL Status
Connection Status Connected
Upstream Rate (Kbps) 832
Downstream Rate (Kbps) 8128
US Margin 13
DS Margin 6
Modulation GDMT
LOS Errors 0
DS Line Attenuation 36
US Line Attenuation 36
Path Mode Fast Path
28-05-2006 00:03:50 4286
28-05-2006 00:03:34 6240.7
28-05-2006 00:02:49 3133.5
21-05-2006 19:14:08 4369.1
21-05-2006 19:13:51 3542.7
21-05-2006 19:13:28 3133.1
19-05-2006 00:00:23 4546.1
18-05-2006 23:59:53 6119.5
15-05-2006 20:56:09 2015.2
15-05-2006 20:55:43 2836.6
15-05-2006 20:55:10 1353.6
14-05-2006 21:59:37 3382.3
14-05-2006 21:59:15 3397.3
14-05-2006 21:58:57 4722.5
14-05-2006 19:16:33 6316.4
14-05-2006 19:16:10 5124.5
14-05-2006 19:15:53 4183.1
I get 6mb/s more often on the adslguide tester and have had 7mb/s once or twice in the early hours. I cant seem to get one download faster than 220KB/s though. I have had 3 ISO's downloading at 200KB/s each thru FTP though which aint bad Wink
