Hardware trouble
Hardware trouble
got my router today and was excited about gettin on the net with ADSL. i set up my router and conencted it to my LAN switch via a crossover cable over said in the setup guide. All was well and i was happily surfing for about 5 minuites when i decided to change the default admin password on the router, which i did, and then reboot it- huge ***** mistake that was. now the ***** thing wont even work and i am gettin really pissed off :/ once i turn it on, all the lights flash, then TX/RX/ADSL/DIAG go off, leaving the "PC" light on for a brief period of 5 seconds, which then goes off along with the router's LED on my LAN switch. Is there any way to fix this or is it ***** ? if so will plusnet send me another?
1 REPLY
RE: Hardware trouble
n/m i fixed it yay!
