Happy but !!
Happy but !!
Hi I just upgraded from aol dial up to plus net adsl, PCI card all went pretty smoothly, but I must have done something wrong somewhere, to start with it went really great, but now every time I try to open a web page it says I am off line but I am not, Can anyone help what have I clicked wrong
RE: Happy but !!
Have you clicked the 'Never dial a connection' in the IE (Tools->Internet options->connections).
Try to ping a site through your msdos window:
ping www.plus.net
RE: Happy but !!
Before you do that, perhaps check this
Open IE and click file and uncheck work offline
RE: Happy but !!
Yeh but this would clear on a computer reboot.
chino
RE: Happy but !!
true but can u ping a web page?
cUnDaLl
1.7 GHz AMD XP, 768MB DDR PC2100 Crucial, 120 GB HD IBM Deskstar
Why do we do it because we can...... Smiley
RE: Happy but !!
> cUnDaLl
Well if the DNS is working yeh. So if he pings an ip address and gets a result but doesn't with the web page...
