Happy Hector!
penguinni
Happy Hector!
Your Tweakable Settings:
Receive Window (RWIN): 14180
Window Scaling: off
Path MTU Discovery: ON
RFC1323 Window Scaling: OFF
RFC1323 Time Stamping: OFF
Selective Acks: ON
MSS requested: 1418
TTL:
(less any hops behind firewall)
125
TTL remaining: 109
Notes and recommendations:
RWIN is in range
Looking good
Example 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 103
Max packet sent (MTU): 1458
Max packet recd (MTU): 1458
Retransmitted data packets: 0
sacks you sent: 1
pushed data pkts: 18
data transmit time: 2.784 secs
our max idletime: 256.5 ms
transfer rate: 39445 bytes/sec
transfer rate: 315 kbits/sec
This is not a speed test!
transfer efficiency: 100%
Good data stream (no/few rexmits)
ICMP (ping) check
Minimum ping: 170 ms
Maximum ping: 174 ms
Ping stability:
174 171 172 172 173 172 170 172 174 172
Looking good
First time I got a perfect score in anything!!Smiley
RE: Happy Hector!
OK here goes..
sacks you sent: 0
pushed data pkts: 21
data transmit time: 2.603 secs
our max idletime: 157.2 ms
transfer rate: 44915 bytes/sec
transfer rate: 359 kbits/sec
RE: Happy Hector!
> OK here goes..
> sacks you sent: 0
If the change in the settings improve your connectivity we will be happy to know the outcome.
From the information that we are receiving we are led to belive that the change in the settings will make an improvement.
Best Regards,
Dave.
| David Watson. Unmetered & ADSL solutions
| Technical Support. for Home & Business
| PlusNet Technologies Ltd. @ http://www.plus.net
+ ----- My Referrals - It pays to recommend PlusNet ----- +
RE: Happy Hector!
My settings seem to be very slick!!
MTU 1458
RWIN 13000
TTL 128
Selective Ack ON
Black Hole Router ON
RFC 1323 scaling ON
these regularly produce 100% data transfer to the US west coast!!
