HOT!!!! New firmware for SAR-110
Anyone interested in the new SAR-110 firmware get over to the solwise forums. Under ADSL/SAR-110, topic Newfirmware.
Just on trying it now.
It allows MTU of 1500, MaxipSess is set at 500 default.
It has increased my plusnet speed test from a max of 470kbps to a sustained speed of around 475kbps, the fastest ive had up til now is 480!!
If ur gonna try the firmware. There's a few things to mention.
1. The default IP for the router is 192.168.1.1 NOT 192.168.7.1 as with usual solwise firmware.
2. The default user name and password for router is root and root NOT DSL & DSL
3. layout is different, but the basic setup for plusnet will apply.
4. You have to MANUALLY enable WAN to WAN traffic.
5. This firmware is intended for the RTA-100 router(basically the SAR-110 indisguise)
6. BEFORE YOU TRY IT GET AN EXISTING FIRMWARE FOR THE SAR-110, IN CASE THINGS DO GO TITS UP!!!!
7. If things do go wrong (speaking from experience here). the firmware you download contains another program called FTPupgrade_02.exe. Unzip an original SAR-110 firmware into the same folder as the mentioned prog, run the FTPupgrade prog and it will upload the firmware thats in the same folder to the SAR-110. (IP back to 192.168.7.1, DSL &DSL)
8. Phew
csogilvie
THis has now been released officially, and still uses DSL/DSL and 192.168.7.1.
Great.
Im still using the RTA100 version, and having no probs.
Will put proper SAR-110 version in, and give it a whirl.
Thx
