HELP with VPN's
glyndev
HELP with VPN's
When trying to create a connection through my router I am asked for the VPN host address or IP number.
I assumed through reading postings on this forum that this should be my static IP number, But am getting an error 751 The remote computer refused the VPN connection.
It seems that I assumed incorrectly. Can anyone put me right.
Glyn Dev
RE: HELP with VPN's
The Host VPN address is the address you want to connect to/terminate the VPN (e.g. your offices gateway) not your own address.
> Glyn Dev
glyndev
RE: HELP with VPN's
Thanks but am still no wiser for that.
Glyn Dev
fonejacker
RE: HELP with VPN's
Where are you trying to connect to using VPN Glyn?
Regards,
Ian
glyndev
RE: HELP with VPN's
> Regards,
> Ian
When I try to create a connection through the DUN I am offered my 56K modem or Microsoft VPN adapter
On selecting the vpn adapter Iam asked for the IP or hostname
I do not have a network other than between my pc and router.
Been trying to connect for 8 weeks to no avail and amrapidly going bald with pulling hair out.
HEEEEEEEELLLLLLLPPPPPPP.
Glyn Dev
