HELP FOR ADSL USERS ?
I`ve only been online since 11Nov 02.the first week.Wow! what problems?....the last 8 Days though.....NO PROBS WITH MY CONNECTION SPEEDS?
I use WINDOWS ME and an ADSL PCI Card(loaded with WAN Drivers NOT LAN!!!!)
Go to http://www.dslreports.com/front/drtcp/html
Down load the zip file to suit your system? Mine was DRTCP021.zip
Now when you run this program a window will open showing various settings? under advice from BT and reading other reports? I have entered the figure 14180 in the top left box "the Recieve Window"..now down in the bottom right there is the Maximum Transfer Unit MTU box...in here I entered the figures 1458...LEAVE ALL OTHER SETTINGS ?
Now SAVE this by pressing SAVE and now you MUST REBOOT your system....
Easy so far?.....now if you run DrTCP again you should see that the figures you entered....are in fact entered!!
Now go to http://dslreports.com/tweaks
run the test and you will see a whole screen of information about your speed test..I also use
http://www.bandwidthplace.com/
Here,run the test, and see the results
first figure=bandwidth divide by 8 to give transfer speeds...although this is already done for you?
I`m sorry ....have`nt checked for other operating systems or Windows XP, but I`m sure you`ll find out some info here....hope it works....bye for now
1 REPLY
weeeck
RE: HELP FOR ADSL USERS ?
Thanx for the gen, keep it up mate
