Got new netgear dg834g, now cant upload by ftp
Just got a new netgear dg834g which all works fine except I cant upload via ftp to any of my websites.
I can download by ftp ok but when I try to upload anything the first about 2k of the file goes and appears on the server then it stops. Have tried 2 ftp progs both the same. Have set the fire wall to allow "all" but still no go.
Can anyone help with this?
Tia Rod
There are some issues with FTP at the moment, it could be related to that rather than the router or connection.
Look at the service status.
I'm running an 834 with default settings and can upload with no problems.
Most people recommend upgrading the firmware on the DG834 to the newer 1.03. Have you done this ?? (If you do, follow the instructions to the letter!!!)
http://www.netgear.com/support/support_details.asp?dnldID=561
Don't upgrade the firmware via wireless
1.03.00 has a fix to improve FTP uploads so an upgrade to this firmware version may solve your problem.
Thanks guys,
Problem solved it was just passive ftp that was the problem.
I called up netgear and they emailed me a fw update 1.03.01
which fixed the problem.
Rod
