Good Morning
Good Morning
Morning,
I waited till 6.35am to connect i thought 6am would have been a bit early.
Anyway i connected right away, and i see a good improvement!.
I'm probably one of the very few online @ this time, but it looks good.
here is a speed test from ADSL guide.
Broadband Speed Test Results
Results from your most recent broadband speed test recorded on 08 November 2002 at 06:35:51.
Your Connection
Direction Actual Speed True Speed
Downstream 464 Kbps (58.0 KB/sec) 533 Kbps (inc. overheads)
Upstream 243 Kbps (30.4 KB/sec) 279 Kbps (inc. overheads)
Can't complain about that. just hope when everyone else comes online it's still as fast.
Well done PlusNet and the engineers who worked through the night.. and Bob too.
I'll let you know how it goes. Smiley
Jason
RE: Good Morning
> Morning,
-snipped-
Hi Jason
Were monitoring this side too and are seeing similar results. The team worked well this morning getting this in place and we will continue to monitor throughout the day and weekend.
Regards
Gary Hough
CSC Manager - PlusNet
RE: Good Morning
I see an improvement too, only marginal, but at least speeds are a bit faster than last couple of weeks. Thanks plusnet and to all who posted all their technical info' here regarding pings, tracerts, speeds etc over the past week. All still a bit beyond me, but all the info' does help one to gain knowledge and I am sure the feedback from users has been useful to plusnet also.
Rog
RE: Good Morning
I beat that one!!
Downstream 472 Kbps (59.0 KB/sec) 542 Kbps (inc. overheads)
Upstream 245 Kbps (30.6 KB/sec) 281 Kbps (inc. overheads)
RE: Good Morning
Morning Jason,
First of all well done to the guys at Plusnet, it looks good from here.
Speed test as follows;
Upstream 246 Kbps (30.8 KB/sec) 282 Kbps (inc. overheads)
Traceroute to portal;
01 106.core.plus.net (212.159.1.106) 10ms 10ms 10ms 10/10/10ms
02 234.core.plus.net (212.159.1.234) 20ms 10ms 10ms 10/20/13ms
03 82.core.plus.net (212.159.1.82) 10ms 10ms 20ms 10/20/13ms
04 atm.core.plus.net (212.159.1.65) 20ms 20ms 20ms 20/20/20ms
05 vlan25.rhogan1.core.quay.plus.net (212.159.15.250) 20ms 20ms 10ms 10/20/16ms
06 alteon1.core.quay.plus.net (212.159.15.230) 10ms 10ms 10ms 10/10/10ms
07 portal.plus.net (212.159.8.137) 20ms 20ms 20ms 20/20/20ms
Roy
RE: Good Morning
Good Morning,
Yes a very good morning!
Our speeds are similarly impressive. Well done to all concerned and thank you for keeping us informed about the problems during this past several days.
RE: Good Morning
Yup... say what you like, but the best thing PlusNet has done recently is communicate! The only thing that goes wrong in life is communications.. if you can get that right you're on to a winner!!
Keep up the good work!
RE: Good Morning
Bit of a newbie to all of this, only been on a few weeks, but i have noticed that web pages where taking an age to open and was getting very frustrated. After logging on this morning i have noticed a vast improvement, will it last?? We will see.
BTW Where do you go to perform the speed test and how do I tweek them?
Cheers
RE: Good Morning
> Cheers
http://www.adslguide.org.uk
http://www.dslreports.com/tweaks. this one also has speed tests from the US west coast.
RE: Good Morning
I'll be back online later.
breakfast calls.
Heres another speed test.
Results from your most recent broadband speed test recorded on 08 November 2002 at 08:28:56.
Your Connection
Downstream 448 Kbps (56.0 KB/sec) 515 Kbps (inc. overheads)
Upstream 242 Kbps (30.3 KB/sec) 278 Kbps (inc. overheads)
Jason
RE: Good Morning
Well done guys & thanks
Downstream 409 Kbps (51.1 KB/sec) 470 Kbps (inc. overheads)
Upstream 238 Kbps (29.8 KB/sec) 273 Kbps (inc. overheads)
RE: Good Morning
Who's a clever boy then!!??
Example 146000 byte download
Actual data bytes sent: 146000
Actual data packets: 103
Max packet sent (MTU): 1458
Max packet recd (MTU): 1458
Retransmitted data packets: 0
sacks you sent: 0
pushed data pkts: 26
data transmit time: 2.642 secs
our max idletime: 194.6 ms
transfer rate: 44445 bytes/sec
transfer rate: 355 kbits/sec
This is not a speed test!
transfer efficiency: 100%
RE: Good Morning
Hi all,
Cry I see to be the odd one out. Just done a speed test and heres the results:
Downstream 393 Kbps (49.1 KB/sec) 451 Kbps (inc. overheads)
Upstream 109 Kbps (13.6 KB/sec) 125 Kbps (inc. overheads)
As you can see the downstream is ok for the time of day but the upstream is still very slow. Obviously from the speed tests i can see that other users are not receiving these slow upload speeds, but im hopeful that when i try a speedtest and non-peak times, the results will be a lot more promising.
Dave Allan
RE: Good Morning
Here is what i got at 8.30am. Its hardly full speed and I really would like it to be better, but it is much much better than it was.
Downstream 468 Kbps (58.5 KB/sec) 538 Kbps (inc. overheads)
Upstream 184 Kbps (23.0 KB/sec) 211 Kbps (inc. overheads)
Downstream 467 Kbps (58.4 KB/sec) 537 Kbps (inc. overheads)
Upstream 179 Kbps (22.4 KB/sec) 205 Kbps (inc. overheads)
Downstream 469 Kbps (58.6 KB/sec) 539 Kbps (inc. overheads)
Upstream 186 Kbps (23.3 KB/sec) 213 Kbps (inc. overheads)
RE: Good Morning
mmmmmm
Downstream
399 Kbps (49.9 KB/sec)
458 Kbps (inc. overheads)
Upstream
241 Kbps (30.1 KB/sec)
277 Kbps (inc. overheads)
Time to tweak think
Jim
