Going slow
Going slow
As far as I can tell I am not connected via the proxy server but I was unable to download from MSN at more than 2kB/s and even unable to complete the ADSLguide speed test.
Going slow
Seems ok this end
link
Cheers
Jon
Going slow
Hmm. The screens seem to update quicker now but the Broadband speed test is still slowing to a crawl and timing out. It got to 20% and now its stuck. Sad
Going slow
Hi Guys
The proxy server is down - problems kicked in earlier this evening and is under investigation:-
http://portal.metronet.co.uk/supportpages.html?a=2
Bill
Going slow
I guess that affects everyone even if they are not using the proxy server? I know I'm not 'cos I never got round to setting it up on this machine.
Going slow
Hi
If your not using the proxy server than your slow down has nothing to do with the problems its got.
Me thinks - rather than doing ASDL speed tests you need to do some of the checks here and then raise a ticket with the results of your labours.
You might like to take a look here as well.
Good luck.
Bill
Edit to add user tools link.
