Give your DSL gateway a reboot as its performance is current
1 10.0.0.138 (10.0.0.13Cool 1.386 ms 1.182 ms 1.071 ms
2 plusnet1-hg3.ilford.broadband.bt.net (217.41.128.202) 24.987 ms 26.687 ms 24.419 ms
3 217.41.128.129 (217.41.128.129) 25.462 ms 23.462 ms 217.41.128.130 (217.41.128.130) 24.978 ms
4 217.41.128.238 (217.41.128.23Cool 25.112 ms 26.354 ms 217.41.128.234 (217.41.128.234) 26.554 ms
5 dolpiaza.core.telehouse.plus.net (212.159.1.114) 453.177 ms * 379.697 ms
6 rt-linx-a.thdo.bbc.co.uk (195.66.224.103) 341.911 ms 354.755 ms 376.961 ms
[root@Faith ali]# traceroute www.cnn.com
traceroute: Warning: www.cnn.com has multiple addresses; using 64.236.16.52
traceroute to cnn.com (64.236.16.52), 30 hops max, 38 byte packets
1 10.0.0.138 (10.0.0.13Cool 1.195 ms 1.101 ms 1.005 ms
2 plusnet1-hg3.ilford.broadband.bt.net (217.41.128.202) 28.505 ms 26.581 ms 25.789 ms
3 217.41.128.130 (217.41.128.130) 24.806 ms 26.131 ms 24.787 ms
4 217.41.128.234 (217.41.128.234) 27.432 ms 27.663 ms 27.933 ms
5 * dolpiaza.core.telehouse.plus.net (212.159.1.114) 395.081 ms 429.931 ms
6 * 213.166.3.149 (213.166.3.149) 315.419 ms 337.487 ms
7 213.232.64.50 (213.232.64.50) 303.307 ms 358.147 ms 372.433 ms
I cant even give you an ADSLGUIDE speedtest as im still waiting for the b l o o d y site to load!!!
Ali
RE: Give your DSL gateway a reboot as its performance is cur
Follow up, this is my worst ever speed test, and if anyone even says its contention then i will personally go to where ever they live and hit them upside the head!
The only bone of contention round here is when is this new pipe being fitted?
Starting speed test...
Do not use your connection until the test has finished.
Downloaded 32768 bytes in 4104ms
Very slow connection, trying 65536 bytes.
Downloaded 65536 bytes in 2791ms
Now starting download test
Downloaded 65536 bytes in 13535ms
Estimated downstream speed is 37Kbps.
Uploaded 133120 bytes in 27491ms
Estimated upstream speed is 37Kbps.
Results stored.
>>> Speed: 37Kbps (down), 37Kbps (up) <<<
Test complete.
Thanks Ali (I just had to have a moan)
I agree, currently I am getting pings of 400-650 while playing firearms. A couple of hours ago i was getting amongst the lowest on the server, 40-80. Pings like these do not help.
<snip>
i'm posting this from btinternet dialup as i cant even connect using adsl. earlier on tonight i could connect, but it froze every 20 or 30 mins.
absolute crap, no faults shown on the so called "up to the minute" service status.... did u hire a bunch of laid off btO monkeysHuh?
sort this ***** service out for gods sake.
Grimbo
I play Medal of Honour and last night at about 10:00 I was getting up to 977 ping (average perhaps 500-600).
This is so frustrating.
