G5 & BT Home Network 1250
Hello
I have a slight problem with my G5 and the BT 1250, i have this thing connedted via the Home PNA Adaptor (USB Socket) every time i restart the comp or wake it from sleep the PNA Adaptor fails to work, the only way it will work is if i remove it from its USB Socket and plug it straight back.
Does anyone have a solution to this problem?
Thank You
1 REPLY
Problem over i used a diff USB Socket and it is working.
