G.DMT or ALCTL
G.DMT or ALCTL
I cant connect under the G.DMT domain at 252/576, but plus net won't let me on at the password loging point.
If I'm lucky it will connect under the ALCTL protocl at speeds of 192/576
It has always been on the G.DMT but now it's all gone funny,
Tried two pc's
TWO Modems
Re installed everything
Contacted Plus net they are looking into it at the moment,
And I get the Dropouts when I am on.
It's annoying,
Moderators note (John) I have removed the copy of this post that you also entered on another thread. Please dont post the same thing on different threads. It only causes confusion and it's better if you have all the replies in the same place.
1 REPLY
G.DMT or ALCTL
The fact you get 512/192 on one mode, means that rate addaption is taking place.
This normaly means there is some loss on the line,t hat the router is taing accout for.
First off, the sugestion, even if you havn't changed anything, it to follow the Troubleshooting & Wireing guide
Second, is there any noise on the line when making calls?
Have you had a localo storm in recent times, that may tie in with then this started?
