Full speed?
Full speed?
Hi all,
i wonder if any of you bright sparks would be able to tell me what speed i should expect when maxdsl goes through... i've got a voyager105 and i live about 400yards from the exchange.
Full speed?
Please try and use the search, there are many threads on this very topic e.g.
http://portal.plus.net/central/forums/viewtopic.php?t=39788
Full speed?
I've seen it... i've got my stats from my modem
Attenuation (dB): 10.5 / 9
SNR Margin (dB): 33.5 / 12
on the calculator do i put in 10.5 attenuation and 33.5 SNR?
Full speed?
If that is your downstream or local figures then yes.
However I can tell you now you will get the max speed. Whether your USB modem can cope is another matter and I would suggest you invest in a decent router as not all USB based ADSL modems will cope with the faster speeds. I know the voyager 105 can't in some cases unless you install a patch to the driver.
Full speed?
Full 8Mb, with ease. My mate had comparable stats and has 14Mb on UKOnline.
Full speed?
Cheers... full speed ahead then!
Full speed?
See my updated reply.
Patch available here: http://www.voyager.bt.com/booster/
Full speed?
Well, checked my exchange staus today and it says it is enabled for maxdsl (Snodland).
I downloaded the booster for my voyager105 and guess what? No speed increase!!
Full speed?
Edit to previous post....
Just read the newsletter, should be on full speed on the billing date!
Full speed?
No, you will be put on the new product name on your billing date. PN will at some later date put a request in to BT to change your line to MaxDSL. When this will be is anyones guess and could be up to 6 months away due to the limited number of requests PN can put through each day.
Full speed?
then why the hell has every plus net customer get a newsletter which says
Your product will be upgraded on your first billing date after 30th March 2006
no wonder this forum is full of confused people who dont know what the hell is going on plus.net are not exactly making life easy for anyone why cant they just give us a straight awnser to the question when will be upgraded?
And if could take up to 6 months i think i will cancel my connection then resign up should get 8mb before all existing customers
