Fujitsu FDX310 and USB2.0
HI All
I have been having troubles with my dsl connection, real bad through put.
To cut a long story short if you are using a Fujitsu FDX310 and you have it plugged into a USB 2.0 port you could have DL problems. Once i plugged it into a USB 1.0 port things started to fly. The motherboard is an ASUS A7V333.
Thought this may help someone.
As for Plus.net thanks for your time and help over the past week, Fantatsic...
Cheers Guys
One very happy Nigel G
1 REPLY
RE: Fujitsu FDX310 and USB2.0
> HI All
If u have a VIA chipset that may be the cause. There were some probs there. I have same modem and it rowksSmiley
Homerlovesbeer mmmmmmmmmm beer
