Fritz!Box setup and speed issue.
I am in the middle of moving to my new flat, i have had my 2mb premier connection moved and i have installed a new AVM Fritz!Box fon WLAN DSL router.
However the modem will only connect if i use the automatic settings and not if i put in the setting manually, and then it only connects at 1mb:
FRITZ!Box Configuration Overview of 27.02.2006 00:03
Product Name FRITZ!Box Fon WLAN Annex A
Firmware Version 08.04.01
WLAN inactive
Night Service inactive
Last Restart 22.02.2006 15:22 Uhr
DSL -Information
Throughput 1044 kBit/s (receive direction) 261 kBit/s (send direction)
Line Attenuation 24 dB (receive direction) 20 dB (send direction)
Signal/Noise Ratio 30 dB (receive direction) 30 dB (send direction)
I have not had a chance to test it with my vigor 2600 yet, but i wanted to see if anyone else is using a Fritz!Box or had problems using this router? or if anyone had any ideas as to why it may connect at the lower speed.
Cheers
R
1 REPLY
Just checked using my Draytek and it shows 1mb, so i guess i am a bit screwed!.
