Firmware for Starter Pack Alcatel Router (AR11)
If you have the Alcatel Router (AR11) supplied in the Router Starter Pack from August to November 2002, this thread on ADSLguide may be of interest to you:
http://bbs.adslguide.org.uk/showflat.php?Cat=&Board=dslrouter&Number=682511
Tim
kissack
Thanks.... off to have a look at this.
Have you ventured flashing your router? a risky business? or did it go ok?
No more risky than flashing any firmware is. Since upgrading, I can use the VPN-1 SecuRemote client to access my employer's network.
Tim
One thing to be aware of is that the router has its own MTU setting with the new firmware, so if you have changed the MTU setting on your PC, you need to change the setting on the router as well.
Tim
