Firewall on KLS-5810
boone70
I have been asked to disable my router firewall to enable a fault check to take place. In spite of reading the manual I can not see how to do this can anyone help please. The router is a
KCORP KLS-5810
Hi
Can you find a section in you router config that lets you set the router to "accept ping from the net", or something like that?
If you find it and set it to do that (probably need to reboot for it to take effect), then you only need to leave your router switched on during the testing.
You can leave your PC's soft fire wall on and can use the pc as normal, including switching it off when you are done. Wink
boone70
Thanks Ian I can manage that.
Eric
Glad to help Eric.
Hope your fault is found and fixed asap.
