Firefox slower than IE
When doing speedtest on the Plusnet tester firefox is slower that internet explorer. I can tell this because when you have ZoneAlarm installed it shows you your current uploading and downloading with green and red bars.
With IE if the green bar (download) is consitently at 4/5 during the test the connection gets about 1.9MB
With Mozilla if the green bar is consistently at 4/5 during the test the connection gets about 1.7MB
Strange...
mike001
both about the same for me
I dont think I could go back to IE after using firefox :-)
You can tune Firefox to outperform IE
Try
http://www.neon-labs.com
Neondaze
Has anyone used the neonlabs tune up facility for Firefox? How good is it? what are your impressions?
LiamM
I just downloaded it and used it now.
Made no difference to me I don't think.
My Firefox performance is very good anyway.
Neondaze
Was that the trial version?
Anyone else used it?
As far as my Firefox performance is concerned, once running it seems to be fine, speedier than IE. However it does seems to take a while to load, certainly longer than IE. Anyone have any suggestions?
LiamM
It was the trial yes.
Firefox loads up speedier than IE for me. On my laptop it used to take longer than IE, but on my PC it's pretty much instant.
And browsing seems speedier also.
Neondaze
I have just used the Tweak Network extension from the Firefox Extensions and Themes website.
The power setting in this extension speeds up browsing noticably. Simple to use. And it's free.
Highly recommend it.
Another Firefox tuner (free) at http://www.firetune.com
