Finding my Sync Rate
curleydel
Hi all, it might sound a bit stupid but how would I go about finding my sync rate . I have a Netgear DG834 v2 Shockedops:
many thanks Derek.
http://www.routerlogin.com/stattbl.htm (points to your router) enter your username and password. Your sync speed will be shown in the bottom table
curleydel
Cheers for that mate, but would that be the connection speed of 7616kbps downstream and 448 upstream.
Many thanks again Derek
yep - that is the connection speed you are syncd to the exchange at. Your actual data rate at which you can download will be lower
curleydel
Thanks a lot for that, and very sorry in being so late thanking you, yer a true gent sir. Derek
