Father decided to move land line to TalkTalk!
I came home tonight and my father has said we are moving to talktalk for out landline (no BBand from them!). It says on there site that there will be no change if an exisitng bbnad connection is on the line, im just checking if that is correct, or that i may loose pnet bband? Anyone with TalkTalk landline with Plus.net bband? How did the change go?
1 REPLY
rz2k7
No problems here. I've got TalkTalk for landline, Plustnet for internet. No downtime as TalkTalk just take over your billing from BT.
Hope this helps.
