Fastest Way to Transfer in Domain Name
Lorian
I need to transfer in a domain name, whats the fastest way?
Change IPSTAG and inport on plusnet portal OR
Can I change DNS etc to Plusnet and get them to do a manual set-up.
Would the second option be quicker, or indeed allowed by Plus?
I'm keen not to loose any email (or as little as possible!).
Jc.
What sort of domain is it? A .uk or another type? If it's a .uk then use the domain tool on the portal and request the tag change from your current host. If not change the DNS and then use the domain tool. Keep a close eye on the domain page on the portal and if nothing has happened in a day or two, raise a ticket.
Re: Fastest Way to Transfer in Domain Name
Jc.
I have recently got PlusNet to host two of my domains, done at different times.
The real delay time is propagating the DNS, so I don't really think it makes much difference either way. In my case I chose the DNS route rather than a full transfer in. As far as I can tell no mail was lost since the mail was still routed according to the old DNS until the new ones propagated - of course I am using SMTP delivery.
Geoff
Lorian
Jc.
Geoff
thanks.
