Face Plate!
Face Plate!
I have head this mentioned a few times, regarding if your db is greater than the limits for ADSL, then a new ADSL face plate is installed.
Question is! how does this help with the db on the line? does it bring it down and if so how does it work? Plus where would i get one?
Simon
1 REPLY
Face Plate!
If your line requires one then BT will fit it for free.
Note: the limits for broadband are being changed on 6th Sept. See this thread, so you may not need one anyway.
It basically gives a much better connection to the line and uses higher quality filters to improve your line conditions.
