FTP setup
FTP setup
Hi all,
I have previously used AceFTP 3, for the upload of files, to my site.
I have installed a new hard drive and reinstalled this programme. Now I can't seem to 'connect' to the Plusnet server, using the settings below, taken from Plusnets FTP setup guide:-
Host: ftp.plus.net
ID mrooke
P/W (Plusnet password)
Has anyone any ideas why I can't now connect to the FTP site?
Thanks in anticipation.
Mick
FTP setup
Hi Mick,
Firstly, since its a "new" installation. Could your firewall be blocking ftp access or your ftp client from getting online?
Secondly you could try ftp2.plus.net.
I am having no issues with ftp, so it would not seem to be a PN problem.
FTP setup
Hi Mark,
Thanks for your quick response.
It was indeed Windows firewall that was stopping it. I have turned it off and all seems OK. I never for 1 minute thought it was Plusnet, hence I never raised a ticket.
I thought I'd have got a warning from the Firewall, letting me know it was blocking the FTP.
Thanks again.
Mick..
craigbrass
FTP setup
Not with windows firewall you won't. Best way is to disable it and get a better firewall!
FTP setup
Hi Flashasp, I used to use Zonealarm Pro but was just using the windows one until I got the PC back up and running. Zonealarm is now on and the windows one is now off.
craigbrass
FTP setup
Gdgd. I suppose you can never be too careful even if not having a firewall for 2/3 hours while installing stuff these days Sad
