FDX310 Install
FDX310 Install
My ADSL was activated yesterday and the modem connected.
The modem appears to connect according to the control panel, but the status is mostly set as
IDLE, NO Signal or TRAINING
The upload/download status only becomes active when connecting via my 56k modem and connected via 0845 No#
any one know where the problem lies...
modem,
line,
Network setting or
IE settings
Cheers
Alex
1 REPLY
RE: FDX310 Install
I had similar problem. Data light on the modem flashing for ages before it remained on-then I could connect to internet ok.
After asking Plusnet support and DSL Warehouse(where I purchased modem from)about this, they both suggested it could be a faulty filter, a replacement seems to have sorted this out.
I have also bought a mains powered USB Hub so that this may also help with the smooth operation of the FDX310 modem.
I take it that you have also configured the settings in Dialup networking with your username and password ok?
Hope some of this helps you.
