FAX to EMAIL problems
zebo-the-fat
I have been using the Fax to email service, it would be very useful to me except for one problem, every fax I receive is distorted. The image is stretched horizontaly (or squashed verticaly). I am picking up the email using Outlook Express V6, and viewing the attatchment with PaintShop Pro V8.
Any suggestions and is anyone else having the same problem?
Altin
No my faxes look just as they were when sent, but I just use the image viewer that comes built in to windows Xp to look at them.
Also using Outlook Express version 6 by the way.
Try using Windows Imaging or Photo Editor to view them, you may have more luck.
Chris
zebo-the-fat
Thanks for the suggestions, I tried it with XPs image viewer, perfect result !
Thanks for the tip, but why will Paintshop not display correctly?
Confused but happy,
altin Cheesy
