Extension from phone line to computer
Where is the best place to buy an extnsion lead...I have just moved house and the telephone point that I have in my bedroom doesnt work...
Any ideas please..
Charz
A.
Well lots of places to choose from!
Argos, or your local supermarket ie tesco would prob' be the most convenient for you. Smiley
BUT... yes there is always a but Wink
Cheap telephone extensions (the ones that come in a reel or have a socket at one end and a plug at the other) can have a big impact on line attenuation and SNR and may caused loss of sync issues.
If you need to run an extension it is must better to hard wire it into the existing master socket (behind the user removable lower part) or a working extension socket. So look for DIY extension kits rather than an extension cable.
Apreciate the help.
Thanx
Smiley
jabb0
Yip i did this for our sky box - neva eva eva again - wires everywhere, iv even got a whole in me ceiling now (as long as you dont look up, ud never notice it, apart from when the fluff kinda comes out and i have to go up there and pull it back a bit its not so bad).
