Extension Cable to ADSL Router
I am having problems trying to connect to my ADSL Wireless Modem/Router using an extension cable. I ahve to use an extension as where the main line is, the modem would be in the way and look unsightly!! Has anyone experienced a problem like this as it works on the main line but not if you run it through an extension cable? Is there a way around this?
Many Thanks
