Exchange check
Exchange check
Is there any way that +net can check what exchange a punter is on? then if someone is having speed or other probs a check of others useing the same exchange or even better the 50.1 modem (or whatever it is) are having similar problems.
No doubt this is not feasible, but i had to ask. :roll:
Ianwild
Exchange check
In theory this is feasible, sort of... In practice this wouldn't give us too much useful information as exchanges tend to have 3 or 4 DSLAMS, and often it is only one of them that goes faulty. That makes the data we would collect almost worse than useless due to the possibility of "False Positives" - ie customer says "I'm on Sharrow (Thats mine) exchange and it's really slow), to which I would reply, so am I, but it's fine - It MUST be a problem at your end. Not a great example, but do you see the problem?
Regards,
Exchange check
Thanks for the answer Ian.
Now that you have explained it the idea was not so great, but at least i've learnt something. :lol:
