Exchange Status
Exchange Status
Hi Plusnet,
Can you please tell me why Sheffield's main exchange is not listed? only sheffield cutler is listed
thanks
Pete
Exchange Status
If you would like to PM your Postcode and phone number, I can check.
However, there are major updates being carried out at the moment, where most of the updates that run the backend are being updated.
Phone numbers are complete, postcodes are 93.7% done (about 0.1% every 3-4 mins) and some exchange names still need to be updated.
Exchange Status
The only reason i asked is because on ADSLguide there are 2 exchanges for sheffield
I'd rather not if it's okay - but thanks for the response Smiley
Pete
Exchange Status
Having looked at ADSL Guide, it would seem that the two exchanges listed for Sheffield are one and the same.
They both point at the exchange code SLSF.
According to the checker database, this is the same exchange on record. I am guessing a ADSL Guide glitch.
Exchange Status
ah, fair enough
cheers
Pete
