Eudora - no support
Eudora - no support
I can't receive my email in Eudora and have to go on to webmail which is very inconvenient.
After trying everything I could think of from settings list (the Eudora help is out of date) I raised a ticket and it has taken 36 hours to be told
(contrary to the smug response from customer support on 15th July to Mike Gundry 'Check out the technical support sections. Its all there - Kevin')
that plus net does not support Eudora.
Please either provide Eudora support - or remove the indication that suggests that you do!
I've posted to adsl guide in the hope that someone there can help
Diane
1 REPLY
RE: Eudora - no support
Going to need more information if you need help.
Can you give details of error messages? whether it sends or recieves, eudora version #, what problems you're _actually_ experiencing...
and i'm sure someone will be able to help.
Marc
