Ethernet Router
filby
Ethernet Router
Hi Plus,
I am a sortof longstanding ADSL customer and have a question..... I want to install a wireless network but find only ethernet wireless routers to buy. Can I change my USB ADSL modem for an ADSL router with Ethernet? Is there a way to allow me to thange the current RJ11 to USB to RJ11 to CatVe Ethernet? I know the cable companies don;t use USB modems anymore....anything you can do to help would be appreciated.
Mark
RE: Ethernet Router
> Hi Plus,
> Mark
If you insist on USB rather than opening up your PC for PCI then get a USB wireless network adapter. You will have to get the wireless Ethernet router/access port. Throw the USB modem in the bin.
PC World (yuk) do wireless USB network adapters, I have no idea if they work though Wink
Ed.
RE: Ethernet Router
> Hi Plus,
> Mark
There are a number of ADSL wireless routers on the market that support pppoA.
Try
Draytek 2600We www.seg.co.uk This has 4 port ethernet as well as wireless
Zxyel 650HW
Linksys are bringing one out end of Jan
Speedtouch 570
Have a look at www.dslsource.co.uk
