Error 721 - BT/PlusNet Frustration
My local exchange was ADSL enabled just over a week ago (18th) and on the 25th a BT engineer called to remove my Home Highway / ISDN box and get the line enabled. Lo and behold, everything worked - I went and plugged in my (temporary) USB modem (Binatone ADSL500) and hurray, after waiting for what seemed like forever I had broadband....... for about an hour Sad
The modem refused to connect and I phoned PlusNet who advised me to try the bt_test@startup_domain username - still no joy, won't even log in with that. OK, ticket raised - PlusNet do some tests - phoneline is fine. Modem synchs OK, ADSL light comes on on modem.
I try a neighbours modem and get the same result - and they have the same problem on their line (they're with OneTel). Everytime you try and connect it makes the connection and then cannot authenticate any username/password. Error 721.
From a quick Google, I understand that this is definitely a BT problem - but with no direct contact to BT other than via PlusNet things haven't been fixed. PlusNet have arranged for an engineers visit tomorrow - but I can categorically say that it is a waste of their time and money when all that appears to be looked at is the routing/authentication.....
Please, can someone from PlusNet please give me a sensible answer as to how/when this will be fixed. 1 hours ADSL usage out of 5 days since activation is hardly good.
:x
Andy
Username: akirkland
I assume that you've already raised a ticket with PN. If it's a BT problem, only BT can resolve it, PN can advise BT of the issue but nothing more. Sad
Yep - opened a ticket with PlusNet - I'm just quite surprised how long it takes BT to look at the issue considering it seems to be a "soft" problem rather than a physical problem with my connection/phoneline. If an entire exchange is off air then I would like to think that PlusNet could put a priority message through to BT and get it looked at more urgently.
Is it usual to wait for this long to get what appears to be a simple issue resolved?
Andy
To be honest I don't how long it should or shouldn't take. The BT engineer will probably be using his/her own equipment, to test the link and advice of any changes that need to be made on their side. If it is a routing entry as you suspect it shouldn't take them long.
I know it's a pain waiting, I had a problem with my line about 6 months ago and I had to wait for BT to come and fix it, but it will get fixed. Cheesy
Aaron
dont rely on PN support :p phone BT and see what they say.. or at least get a contact number from the man they send to your house.. as that way it will at least be wtih BT that you talk and not to the support ppl here.
The problem is, BT can't talk to the customer. You as a PlusNet customer, are not a BT customer (in not in the eyes of ADSL).
The customer relationship for BT, is between PlusNet and BT.
The problems here are being masked by the Bank Holiday. 3 of those 5 days are a period where both the people that accept new fault reports at PlusNet and those at BT are not working.
The fact this sounds like a BT related issue is good. As you should be able to have your billing date adjusted to account for the time you have been unable to avccess the service.
Result!
BT engineer phoned yesterday afternoon (yes, a Bank Holiday!) and confirmed that there was a problem with the MUX in the local exchange and he'd re-racked / thumped / replaced it and everything worked again.
For once I'm impressed with a service in the UK!
Cheers,
Andy
