Erratic speed tests....
Hi, I've just performed some speed tests as I've purchased a new ADSL wireless router and I'm finding the results rather weird. The figures I'm getting with my 2mb connection range fron 0, yes zero, to a max of 1084.2 kbps. I went into my router setup and it gives me this: ADSL Link Speed 288 kbps
ADSL Link Speed 2272 kbps
SNR 28db
SNR 20.0db
CRC 0
CRC 0
As I was the only person accessing the internet at this time can I ask if this normal?
Thx
Chris
i am also on 2meg mate and my speeds are abysmal...i used to average around 1800 on the speed tests, that has now dropped to under 1000...i have spoke to plusnet several times but they say everything is fine, for some reason i dont believe them
Hi and thx for your reply, I've just done another test and they seem fairly variable but not too bad:
1908.4, 1913.6 & 1384.6 kbps, anyone else with any comment to make?
Chris
its coz of my useage this month mine was slow mate, i didnt know there was a 20gig limit that had come into place, a complete joke mate, i could get through 20gig in a night let alone a month....after 12pm last night my speed tests were great, had download speeds of 238kbs off plusnet
Sorry, 'mate', but you didn't read the small print, or the e-mails that plusnet sent out...
ChrisC
download speed checks are crap as well
I have only been with plusnet for a week and even I see a low if not unusable speed from my connection. Below are my speed ratings, and I have only downloaded a mere 10gb in a week. Crazy, and I have complained because a 2mb line should be just that, or have I been duped.
13-01-2006 20:35:53 936.6
13-01-2006 19:34:52 631.1
13-01-2006 19:34:16 665.9
13-01-2006 19:34:02 509
13-01-2006 19:33:45 472.8
13-01-2006 19:33:26 616.3
13-01-2006 19:33:10 939.5
13-01-2006 19:32:51 637
13-01-2006 19:28:47 586.5
13-01-2006 19:28:26 591.1
13-01-2006 19:28:03 434.5
13-01-2006 19:27:35 402.8
WayneH
