Emule/Edonkey and Winroute Pro help?
Can anyone help me in the setup of Emule, I keep getting as lowid, I am using a SAR703 router with all the required ports being forwarded to my PC. I try and run the lowid test page for port 4662 and get a resest(!) error, I then installed Winroute Pro and I now get a "Stealth" firewall message, obviously something is not setup correctly, can anyone help??!! PLEASE??!!
RE: Emule/Edonkey and Winroute Pro help?
<snip/>
Have you tried the Solwise forum?
http://www.solwiseforum.co.uk/forumdisplay.php?forumid=41
Graeme -
Although your router's ports are open, your software
firewall might not have the UDP and TCP ports
opened. I had the same problem with my Zone Alarm
pro setup. By default everything is blocked, and I
had to manually open the required ports on the GUI
setup.
