Emails not getting through on username@mail.plus.net
Should this address work? This is the default outlook express address used when I set my plusnet account up on it, and all my emails are sent from that address, but nothing is recieved on that address. I have been wary for a while, but I just tested it now from another account. The anything@username.plus.com works fine, thanks for any hints!
anything@username.plus.net is the correct format.
username@mail.plus.net is incorrect and will not work.
The mail.plus.net is what you use when setting up the POP3 section of Outlook Express and relay.plus.net is the setting for the smpt section
ahh thanks for clearing that up, now I know anyway! cheers
Sorry I have mistyped there it should be .com at the end and not .net for the email address ie anything@username.plus.com
