Email problems!
Email problems!
i cant send any mail
i can receive but cant send using outlook express getting annoyed now!
have done eveything that ive been advised to but to no avail
any ideas?
chers
chris
Email problems!
Are you actually connected to PlusNet (using their dialup or adsl)? If you're using a different ISP, you can't use the outgoing mail server.
Email problems!
They are connected via PlusNet.
What error messages do you get when trying to send mail? Are you able to use webmail for sending email?
Has it worked previously?
Chris
Email problems!
Another note. What from address are you using in your mail client?
Email problems!
it has been set up how i was told
im connectings using plusnet!
Email problems!
That didn't answer the question.
What server are you using to send. Is it relay.plus.net ?Huh
