Email attatchments - how big
madswitcher
Just as a point of interest,
is there a maximum size of attachments that one can use on Plus email?
thanks, Mike
100 meg is the maximum file size that you can send from the Plusnet server but you may find that whoever you send it to wont be able to receive it due to restrictions on their server?
I once sent a 70meg video to this website, not knowing that the address i sent it to then resent it to all the staff at the site...they wern't very happy Shockedops:
If you intend to send a large attachement I would sent a simple email asking if it is OK to send the large email of xxx MBytes to the email address and if not is there an alternative they would prefer. Many email systems including corp ones have limits imposed on email sizes so It's best to check before sending.
madswitcher
Thanks Guys
I was asking on behalf of a guy on one of the newsgroups who is disgruntled by the BT-Yahoo cap he now has. He frequently get 10M PowerPoint files so from the above this should not be a problem.
Regard, Mike
