Email SMTP outgoing authentcation problem....
Hi everyone,
I'm at uni at the moment and i'm trying to send email using my plusnet account. recieving email is fine but I can't send. I'm guessing it's a problem with authentication (maybe ip address as my uni obviously has a different one). Is there anything I can do about this?
cheers guys.
1 REPLY
Yes and No...
1) You can only use relay.plus.net from a plusnet IP
2) To get this to work, you must change the smtp server for all your accounts to use the one your Uni uses for sending outgoing mail.
