Email Problem
Email Problem
I can't seem to access my email via Outlook Express. It was fine untill yesterday but now I get the following errors :-
The connection to the server has failed. Account: 'Barry', Server: 'mail.plus.net', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
The connection to the server has failed. Account: 'mail.plus.net (1)', Server: 'mail.plus.net', Protocol: POP3, Port: 110, Secure(SSL): No, Socket Error: 10061, Error Number: 0x800CCC0E
Webmail seems fine.
Any ideas?
Email Problem
If you have not already done so try a cold boot of your PC.
I have had this in the past and a reboot sorted it out.
Email Problem
IF a reboot does not sort it, your Outlook Express setting have become corrupt.
A quick search on Google with the error numer 0x800CCC0E will bring up a number of results.
Email Problem
Also if you have a separate router try a power cycle on it.
Also try the usual tests with firewall and ant-virus scanner disabled
Email Problem
ok thanks guys!
A reboot seems to solve it, but it's happening all the time!
Bloody annoying ...
Email Problem
Then it's something local on your own PC.
I can't tell you what though as it's only happened a couple of time to me and each time I can't recall what event or program was running before I tried to check my mail.
Email Problem
Try a different mail client such as Eudora (OK, some will moan, but mine works OK) or Thunderbird.
Have you tried looking into the settings of yoru firewall & antivirus as petervaughan said , as it seems like some sort of timeout?Huh
Email Problem
Is port 110 the correct port for the lpus.net mailserver?
Email Problem
Port 110 is the normal incoming POP3 server port you connect on - i.e. mail.plus.net
What is lpus.net and how does this relate to your problem?
Plusnet use mail.plus.net for port 110, and relay.plus.net for port 25 (SMTP outgoing).
keithcalder
Email Problem
Think is you swap the I & P in Ipus.net you'll have fixed the problem. Smiley
Email Problem
I would expect lpus.net is just a typo for plus.net Cool
Email Problem
plus.net is still not the mail server though which is why I queried it.
Email Problem
It was indeed a typo Shockedops:
I was just trying to configure my firewall to see if it was that which is stopping my mail from working
