Earth calling PlusNet.. fix the DNS!!
Earth calling Tech support are you are you alive? DNS is messed up..... and so is the upstream i told you about early this afternoon......
*sighs*
Must have all gone out to a party Wink
Jason
RE: Earth calling PlusNet.. fix the DNS!!
k mate dont you read service status under connectivity!
> *sighs*
> Jason
I read the status every time i login, and that message was NOT there.
I informed them of the troubles earlier and nobody did anything.
YES im aware, are PlusNet?.
Me thinks they are sleeping.
Portal was giving a weird TXT message b4 that updated msg appeared reading "HEALTH CHECK OK"
Instead of the normal portal pages..
i'm all there and a bit more Smiley
If i do tech support can i have a fee subscription?! Smiley
Jason
I could not be arsed to wait anymore, im now using BT's DNS servers, please
note if you use them you will have to reconnect.
213.120.62.100
213.120.62.101
Not sure if we are suppost to do this, but i dont see a problem.
LOL thanks MR TAC..
i'll do the same! been waiting on a connection all day.
PlusNet don't refund us everytime they mess up, which is quite often.
So yes i'm using those servers too!
I'm paying for it!!
Thanks Smiley
Jason
WoooooooooHooooooo!!
Thanks MR TAC.
BT servers are working good.
I see no problem using them either until PlusNet get thier own sorted.
we are paying for a ALWAYS ON service Smiley
Jason
