Early morning tests=pleasants surprises. Comments welcome
I do so hope that the following is not going to bore everyone. I have read with interest and in awe of those who post the technical stuff here. I have played with settings a bit and run so many speed tests since having adsl. Finally in the early hours of this morning I have some speed results that are very pleasing. How accurate they are I do not know. I sincerely hope that you do not mind that I have copied and pasted them here.
Thank you,
Rog
Speed Test Report
Broadband Speed Test - for Telewest blueyonder - 512k service
By Daniel Elwell - dannyelwell2001@msn.com
Get this test from http://www.vantage.pwp.blueyonder.co.uk
*** THIS TEST IS NOT OWNED OR PAID FOR BY BLUEYONDER ***
If you like this Speed Test, please make a donation to help me
meet the development costs. No ISPs pay me to maintain this test.
More information: http://www.vantage.pwp.blueyonder.co.uk/donate.htm
These results are only a snapshot of this particular moment. They are dependant
on any other Internet use on this computer and any delays
on the Internet. To improve accuracy, run the test several times.
Section 1: General Ping Results
A Ping test is the time taken for a server to reply to a request
Blueyonder Server:
23ms - Normal - it's about right!
UK Server 1 (www.demon.net):
24ms - Normal - it's about right!
UK Server 2 (www.bbc.co.uk):
UK Server 3 (www.ic24.net):
27ms - Normal - it's about right!
USA East Coast Server (www.yahoo.com):
107ms - Fast - very fast response
USA West Coast Server (www.lycos.com):
European Server (www.marcopoly.com):
111ms - Slightly off - it should be less than 150ms
Section 2: Custom Server Ping Results
These results are to four user-definable servers.
Blueyonder Counter-Strike 1:
28ms -
Blueyonder Team-Fortress Leage 1:
30ms -
BarrysWorld Master Server (all games):
28ms -
Barrysworld Quake III Arena:
22ms -
Section 3: Download Speed Results
Three downloads are tested; one from one of your ISPs servers, one through your Transparent Cache and one through an alterntive cache. This will give you an idea of how capable your connection is. Note: You should take the highest download speed into account.
Telewest blueyonder - 512k service Server Download:
62KB/s (496Kb/s) - Perfect - running at full speed!
Download through Transparent Cache:
66KB/s (528Kb/s) - Superb - much higher than expected
Download through alternative Cache (webcache.bt.net):
Section 4: Packet Loss
50 Ping Requests are sent to your server. The packet loss is measured by how many of the packets don't bounce back to the client. High packet loss may slow down your connection.
50 packets were sent, 50 bounced back; 0% loss (estimated)
Fantastic - no packets dropped!
Section 5: Transparent Cache Page Fetch Time
This test times how long your Transparent Cache takes to fetch a page from the Internet. Please note that this test is subject to many different parameters and sometimes may not be 100% accurate. This test can be used to show delays when trying to view Internet sites. The timing takes place from the moment the request for the file is sent to the moment the proxy server responds.
Average time taken to retrieve a page: 30ms - Fine, nothing to worry about
Test Statistics:
Information on the test
Time and Date: 10/11/02 04:29:39
Test duration: 70 secondsIP address: [Not Disclosed]
Username: [Not disclosed]
Test Version: 2.81
Broadband Speed Test - www.vantage.pwp.blueyonder.co.uk
Speed Test Report
Blueyonder Server:
44ms - Normal - it's about right!
30ms - Normal - it's about right!
108ms - Fast - very fast response
123ms - Normal - to be expected
104ms - Slightly off - it should be less than 150ms
30ms -
30ms -
30ms -
23ms -
65KB/s (520Kb/s) - Superb - much higher than expected
Average time taken to retrieve a page: 33ms - Fine, nothing to worry about
Test Statistics:
Time and Date: 10/11/02 04:26:32
Test duration: 71 secondsIP address: [Not Disclosed]
Test Version: 2.81
From: http://www.adslguide.org.uk/tools/speedtest.asp on 10 Nov. 02
Downstream 480 Kbps (60.0 KB/sec) 552 Kbps (inc. overheads)
Upstream 246 Kbps (30.8 KB/sec) 282 Kbps (inc. overheads)
Downstream 476 Kbps (59.5 KB/sec) 547 Kbps (inc. overheads)
Upstream 249 Kbps (31.1 KB/sec) 286 Kbps (inc. overheads)
Upstream 247 Kbps (30.9 KB/sec) 284 Kbps (inc. overheads)
From Plusnets testing page:
Your current bandwidth reading is:
499.30kbp
which means you can download at 62.41 KB/sec. from our servers
491.50kbps
which means you can download at 61.44 KB/sec. from our servers
491.40kbps
which means you can download at 61.42 KB/sec. from our.....
Speed Test Report
Blueyonder Server:
25ms - Normal - it's about right!
28ms - Normal - it's about right!
106ms - Fast - very fast response
107ms - Slightly off - it should be less than 150ms
30ms -
30ms -
29ms -
22ms -
61KB/s (488Kb/s) - Perfect - running at full speed!
Average time taken to retrieve a page: 18ms - Fine, nothing to worry about
Test Statistics:
Time and Date: 10/11/02 04:22:44
Test duration: 69 secondsIP address: [Not Disclosed]
Test Version: 2.81
If you got this far down the posting, as I said earlier, hope you are not bored, but you didnt have to scroll this far. I also ran several tests from American sites and results were most favourable from there too. Here's hoping that things remain this way-I will keep my eyes open for flying pigs at dawn though.... Anyway, whether these results are accurate or not, they have made me happy this morning anyway.
RE: Early morning tests=pleasants surprises. Comments welco
Oh, almost forgot, there is no reason whatsover(in my humble opinion) for a reply to include all of the original posting, as per this example.
This has been mentioned time and time before in the forums. If there is a specific point one is replying to, then it may be relavent to leave that in, surely the rest can be deleted.
Thanks,
Rog
Saturn
Yes, a good point but one that I think might be partly doomed to failure because of the forum reply page design. This would be a good one for Support to consider as a potential enhancement. I.e. when replying start with a blank entry by default, but with a button somewhere to enable inclusion of the original message.
SUPPORT - A SUGGESTION FOR YOUR CONSIDERATION PLEASE.
After I have clicked on reply, I just highlight text in the box and right click and click delete-seems to work for me, but a blank page as default is a very good suggestion.
Rog
Saturn
I'm just lazy though (and I like buttons to press!).
A proper php forum would be even better.
