EMAIL - outlook n plus net problems
hi
weird problem
i will send a NEW email message from outlook get a reply in outlook, then send a further reply, n not receive a reply for days, and when i log into plus nets mail beta program y reply is that there?
this is happening a lot n causing confusion??
any ideas why im having these problems
Are you sure your reply to address which get's sent out with any emails you send is correctly spelt/formatted - typo perhaps?
i dont have a reply to address
i ereceive a reply in outlook then when i reply to that reply it goes to the beta program
its not my fault its sum bug sumwhere
