E-mail Query using Outlook Express
I have set up an additional mail box the problem is i can recieve messages but cant send any? Am i using the correct outgoing mail server?
relay.plus.net
thx
yes.
What error messages are you getting.
the following one
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'joe.bloggs@anything.com'. Subject '', Account: 'mail.plus.net', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '553 sorry, that domain isn't in my list of allowed rcpthosts (#5.7.1)', Port: 25, Secure(SSL): No, Server Error: 553, Error Number: 0x800CCC79
Regards
If you are connecting from a different ISP you must use thier outbound mail server. check with your other ISP for the outbound mailserver and make the required changes and this will fix your problems.
Chris
Ianwild
Yep - Chris is right on this one, try it with "mail.btopenworld.com" as the outbound mail server :roll:
Regards,
Ian
thx guys yep i`m away from home and using a friends BT account to get online, but the good thing is i get back to the broadband connection on Monday.
Thanks again
